Wifi 3 TEMPERATURE SWITCH
A project log for WiFi 3 channel Temperature Switch
The temperature switch takes three readings from three sensors and displays then on oled and also according to the conditions switch relay
jmcservvjmcservv 03/22/2017 at 22:230 Comments
I have built the first prototype and tested all features. i wrote the software in a way to be scale able and be able to add more features in future.
All components fitted nicely, the display shows the temperatures as expected, now testing the wifi option
To Do: finish the setup menu options .. and fit everything in the 32k flash ..
