Hackaday.io Hackaday.io
Sign up Log in
Non-blocking analogRead()'s for Arduino
The goal of this project is to get non-blocking analogRead()'s added to Arduino core libraries.
jacob-christJacob Christ
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
6 comments
18 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 6
  • The 2017 Hackaday Prize
View Gallery
337
6
18
17
Team (1)
  • jacob-christJacob Christ
Join this project's team
ongoing project
arduino ChipKit 2017HackadayPrize analogread nonblocking
This project is submitted for
  • Design your concept
This project was created on 03/23/2017 and last updated 9 years ago.
Description
The goal of this project is to get non-blocking analogRead()&apos;s added to Arduino core libraries. I recently made a change to chipKIT-core libraries to add this feature. It had the surprising effect of making existing hardware 2.5 to 5 times faster. 1. The primary challenge this project addresses is the ability to wrangle hardheaded Arduino developers into taking pushes from down stream 2. I&apos;m not sure I can solve this problem of hardheaded developers, not am I sure I want to being one myself, but I&apos;ll try. 3. This project makes the world better by breathing new life into old hardware! 4. See picture to the left. 5. These changes have already been published in the chipKIT-core repo, but a Arduino version is needed. <a href="https://github.com/chipkit32/chipKIT-core/" target="_blank">https://github.com/chipkit32/chipKIT-core/</a> 6. BSD 3-Clause
Files
chipKIT-core 1.4.0 Non-Blocking Analog Reads.pdf
Original foils I created after implementing in chipKIT-core
Adobe Portable Document Format - 662.13 kB - 03/23/2017 at 20:29
Preview
Project Logs
Collapse
  • Started a Discussion
    Jacob Christ • 03/23/2017 at 20:31 • 1 comment
    Last night I submitted a suggestion to try to impliment this on the Arduino Developers form...
    https://groups.google.com/a/arduino.cc/forum/#!topic/developers/eTFLXvUiVZA
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
K.C. Lee wrote 03/31/2017 at 12:17 • point
If you only need a single channel, just need to turn on the free running mode in the ADC, then you can grab the latest results anytime you want.  Most microcontrollers have something like this.  On chips with DMA, just grab and process whole block of data.  Some might even let you specify the channel sequence.
For a PID loop, you want to take the ADC snapshots from a hardware timer and not a software timing loop.  Jitters in the sampling time affects the D term in a PID controller.  Faster isn't necessarily better.
https://www.chiefdelphi.com/forums/archive/index.php/t-83734.html
Jacob Christ wrote 03/31/2017 at 17:03 • point
I rarely use a D term but good to know. Had never thought about this but a good point.
K.C. Lee wrote 03/31/2017 at 17:18 • point
I use the D term quite a bit.  It gets you a faster settling time while controlling the oscillations/overshoots.  As with finite derivatives, it is unfortunately prone to noise.  :(
Jacob Christ wrote 03/27/2017 at 17:57 • point
Sounds like a blocking mental-block.
Eric Hertz wrote 03/31/2017 at 06:02 • point
Eric Hertz wrote 03/24/2017 at 03:44 • point
ah hah! "Non-Blocking" is the word that was on a mental-block for me
My somewhat odd and random project of building a racing mower( was brought on by my arduino ecm )
Project Owner Contributor
Racing Mower
cg72cg72
Debug Arduino Uno in VScode with a ATtiny85 debugWIRE probe
Debugging Arduino Uno in VScode
deqingdeqing
This project is Arduino Pro Mini based and includes my mini shields prototypes.
XBee and FPV cam spy car
hubacekphubacekp
This project is perfect for those who want to take on an intermediate arduino project, and want to get some hands on mechanical experience
BUILDING AN ARDUINO BASED ROBOTIC HAND
stan-averystan avery
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Non-blocking analogRead()'s for Arduino", please tell us the reason.
Send message
Remove Member
