​Time for the firs tests.
A project log for Web Enabled Led Matrix
Not just any Led matrix you've seen... You can play Retro Games like Pong from anywhere in the world with your phone.
cabattistacaBattista 06/10/2017 at 09:440 Comments
The firs scetces I did were simple one liner color set methods.
I tried diferent colors and brightnesses to see how bright it would be with just the usb power.
In theory each led uses 100mA, I have 200 leds wich equates to 30A! of power usage. So I will ad a bigger power supply later.
Old Pc power supplies are great for this application as they can proivide up to about 40A on the 5V rail.
