Double Action Keyboard 1.0
A project log for Double Action Keyboard
A keyboard with double action functionality, designed to make typing easy and comfortable.
jaakob-lidauerJaakob Lidauer 06/14/2017 at 14:360 Comments
I started building a second version of the double action keyboard, it is based on a Teensy-LC and the case will have a removable wrist rest. The layout will be slightly different and the navigation button is going to be bigger and more comfortable to use. Otherwise the keyboard is going to be quite similar as the first one.
This time I ordered the PCBs. Here are some pictures:
