Project schematic created using gschem
A project log for $60 bluetooth head mounted display.
The HMD is bluetooth enabled and compatible with both Linux and Android.
Tony E. NazzalTony E. Nazzal 07/26/2014 at 17:550 Comments
gschem is a free schematics editor and is part of the gEDA project. I found gschem fairly intuitive and easy to use. The first thing I did was to create the custom symbols for my components and add them to the gchem config file. After the components were created and loaded, I simply added them to the project and connected the pins.
More information can be found on the gEDA wiki: http://wiki.geda-project.org/geda:gschem_symbol_creation
