USB C
A project log for Orthrus
SD card secure RAID USB storage
nick-sayerNick Sayer 07/19/2020 at 16:240 Comments
I've updated the design to swap out the micro-B connector for a USB C receptacle. The only real change this requires is adding the CCx pull-down resistors. I've also added a ferrite bead on the power input to prevent noise getting sent back down the USB cable.
