Firmware success
A project log for Orthrus
SD card secure RAID USB storage
nick-sayerNick Sayer 10/04/2017 at 14:220 Comments
I got Orthrus v3 hardware working all the way as a disk drive last night. There are a few bugs in Start's code that you have to work around:
There are still a couple of bugs to work out - mostly centered around the handling of situations where cards are removed or missing.
Performance is not as good as hoped. Throughput is around 540 MB/sec. Halving the SD card clock doesn't appreciably change throughput, so this may be being limited by USB. But even at only ~5 times faster than before, it's now actually usable as opposed to unacceptable.
Another couple of days to polish the firmware, and I think I'll be able to send some units off to the HP judges!
