Enabling Semihosted Printf
A project log for Notes on Using SystemWorkbench with STM32 BluePill
I finally succumb to IDE madness... for awhile.
Al WilliamsAl Williams 04/03/2017 at 23:483 Comments
If you don't want printf to go to a serial port, perhaps you'd like to have it redirect to the gdb console (inside Eclipse).
1. Add to your linker options:
-specs=rdimon.specs -lrdimon
2. In your debug configuration, find Run Commands and add:
monitor arm semihosting enable
3. In your main() make this call early (before calling printf):
initialise_monitor_handles();
That's it. Now printf will go to your console.
Al Williams wrote 04/04/2017 at 01:55 point
Don't forget this lets you open files on the host for read/write, do console input, etc.
Al Williams wrote 04/04/2017 at 01:49 point
Although that's slow, so you can also call fflush if you don't put a newline at the end of things.
Al Williams wrote 04/04/2017 at 01:47 point
Oh yeah. You might want to put:
setbuf(stdout,NULL);
In to keep stdout from buffering.
