Just got a new delta in. Going to be making version 3 of the machine. Hopefully better this time.
06/22/2017 at 15:04 • 0 commentsJust got a new delta printer in. Hoping to make this one even better this time. More portable and easier to work with.
We will see where this one goes.
New video for 3d printer with auto ejection and web based print queue.
06/11/2017 at 22:05 • 0 commentsThe video is thanks to the AV group at my local maker space http://spark.coop and Edwin Nieves.
Going to be at CREATiNOVA. A free event hosted in new London ct.
06/10/2017 at 02:58 • 0 commentsShowing off the 3d printer at CREATiNOVA
A
It is located in new London ct. Pop on over if you are in the area to see a demo.
https://www.creativityinnovationfest.org/creatinova/
I bought new Inc cartridges for the incject today when I ran out so things should work good tomorrow.
Getting a new video cut and edited. This one is going to be a really nice video.
06/10/2017 at 02:51 • 0 commentsSo I talked to the AV people at my maker space and filmed a nice set of clips detailing the printer and how it works.
Going to be posting it up either late tomorrow or early Sunday.
This one is going to look much better than my previous videos.
Been pooping out parts for a few weeks now
06/05/2017 at 04:16 • 0 commentsOne of the guys over at the maker space I frequent suggested I use the rubber material that mouse pads were made from on the bottom of my print tabe in order to grip the paper better.
Well it worked out wonderfully.
Linear actuator for trap door clamping
05/07/2017 at 05:00 • 0 commentsi have still been having some trouble with tall prints. Some times the paper will shift a bit. I believe this can be prevented with a proper clamping force applied under the trap door. Off to eBay to source a linear actuator.
Slide show detailing how is all is coming together
05/04/2017 at 03:30 • 0 comments -
Investigating using matter Control's slicer but having a few problems
05/03/2017 at 03:53 • 0 commentsI am trying to move away from using slic3r to matterslice.exe include with matter control.
I have started to use matterslice.exe include with matter control as it makes amazing support structure that is easy to remove.
I have been having trouble making it work off off a a settings ini file.
Going to be seeing if I can get some help on this as it will makes the prints better.
If any one has any insight on using matter controls slicer from the commmand line please contact me.
3D Printer auto eject system overview presentation
04/29/2017 at 19:48 • 0 commentsMade a little presentation about the system. Talks about how all the componets work together.
https://docs.google.com/presentation/d/11ar4LAsOycPXjSWupaWiF28OccQcgd3ohX5cbBPk4h0/pub?start=false&loop=false&delayms=3000 -
Automated 3d printer ejection system has worked
04/29/2017 at 01:37 • 0 comments3d printer auto eject has worked for about 15 convective prints and is still running. Felling pretty happy right about now.
