Speed and accuracy greatly improved!
A project log for Full Stack GPS Receiver
From raw RF samples of the GPS L1 C/A signal to a position fix, in a completely open fashion
Mike Mike "Hamster" Field 05/03/2017 at 10:390 Comments
I thought up a away to improve the speed - now uses about 3% of a CPU core per channel. The speedup also allows the early/late tracking that is used to follow the Space Vehicle's Gold code to be change from +/- 1 .0 chip (1/1023th of a ms) to +/-0.75 chip.
This allows more accurate tracking, giving more accurate pseudoranges and more precise fixes. Adding an averaging filter removes quite a bit of the remaining noise too.
Now I am in the ballpark of a commercial GPS module!
Here is the console output as it runs, showing it as it tracks 7 channels:
