MK2: (hand)soldering
A project log for YaMseK
Yet Another Modular Split Ergonomic Keyboard a custom 40-60% keyboard with a columnar+curved keyboard layout and an attached thumb-cluster
johschneiderJohSchneider 01/11/2024 at 17:500 Comments
the pcb is straight forward
- smd diodes: according to their markings, bottom side
- io-expander: only one per pcb, bottom or top
- switches: in triplets, aligned with the help of a small jig
the thumbcluster is a little more effort :-)
1. the printed part has M3 screw holes, which need to be tapped
2. each switch is prepared with a THT diode
3. each switch gets it's own "column" wire, threaded through the PCB slot
4. the "row" wire is prepared: 4cm+4cm+6cm+4cm+4cm+spool
5. threaded through and soldered to the switches
6. the wires are cut to length, checked that they run all through the central hole (and not any small adjacent ones) and stripped
7. connecting to the pcb:
since the pads are available on both sides, and spaced for a ribbon cable, alternating between front and back
 Note on the column order, and color coding:
chose *the same* color codes for the left and right assembly. since the pcb is flipped, so is the order
e.g. the left side has from left to right C0...C5; where as the right side has from left to right C5...C0
in the above picture, the leftmost key has a yellow wired, connects to C5 pad - and would do the exact same for the right side
