Synthesizable
A project log for One-instruction TTL Computer
A breadboard-able computer which uses only a single instruction - MOVE
justin-davisJustin Davis 05/04/2017 at 14:571 Comment
I've been working on changing the code so that it is synthesizable. I was originally planning on only simulating and so I took some shortcuts. I was loading the RAM while in reset, so I implemented the ROM and put the instructions in the declaration line instead. Then I took the clock and reset lines out.
Next up is making a chip-specific wrapper for my code. I grabbed the pin-constraints file for the Cmod board from the Digilent website. I need to make a few extra modules like the clock module and a reset. And I'll want to put a few extra features in there like halting the clock and stepping the clock manually. And I'll need to pass the RAM signals out of the chip, and then make the UART interface. Then it should work!
Yann Guidon / YGDES wrote 05/04/2017 at 15:39 point
Easier said than done :-)
Good luck !
