Update: 30 April 2017
A project log for [ModAir] Monochrome LCD Modules
A LCD graphic / character display module for the ModAir project
reneRene 04/30/2017 at 20:250 Comments
Current hardware status: all peripherals have been tested and work as expected. The following LCD modules have been tested and work:
Current firmware status: about 40% complete. So far only the functionality for listing attached modules and their parameters as well as accessing any of the remote console menus has been implemented on the Nelytech LCD. The identical code should be re-usable for the other graphic LCD modules, by simply replacing the glcd.c/h files with the appropriate driver. Widgets and their configuration menus still need to be implemented.
