Just released Visuino version 7_8_3_1
- Brand new revolutionary code generation design producing extremely efficient low Flash/ROM and especially RAM usage - up to 90% less RAM usage by the generated code, and up to 60 % less Flash/ROM usage
- Up to 90% execution speed improvement by the generated code
- A Completely Free Mode of Visuino now available for entry level users and students
- Added initial Raspberry Pi support
- Added initial Peguino ESP32 Brick support
- Added support for ESPCopter
- Added support for Arduino Every
- Added NINA-B1 support
- Added support for Adafruit proportional fonts in the graphics
- Added Angled Line in the graphics
- Added support for Centered Rectangles in the graphics
- Added support for Text and Array in the Structure and Packet components
- Added CPU Time component
- Added RemoteXY mobile device remote support
- Added support for complex arrays
- Added support for Funduino Joystick Shield
- Added support for setting IP addresses during execution
- Added support BMP280 Temperature and Pressure sensor
- Improved ESP8266 and ESP32 sockets
- Added a large number of math, array operation, and text components
- A lot of IDE stability improvements
Updated version of the User Code Component , and Experimental Sub Design support are included in Visuino Pro available in the MeWe Community:
mewe.com/join/visuino-visualarduinodevelopers
![](https://cdn.hackaday.io/images/1628171564117980157.jpg)
