Synth implementation : key release handling
A project log for PC Keyboard becomes synthesizer / drum computer
Converted an old PS2 keyboard into a synthesizer/drum computer/... using arduino nano.
serdefserdef 07/27/2014 at 14:020 Comments
The teensy ps/2 keyboard library was extended to support notification of key releases.
I maintained backwards compatibility and added 2 new public methods :
add 'rel' to the usual method, and provide an iskeyrelease bool parameter.
this parameters is referenced and set to true when the keypress was a release..
Only a few keys are supported right now. I plan to refactor  the code to eliminate redundancy and implement full playable keyboard.
So the code below shows a simple example of sounding a synth sound as long as key 'c' is pressed.
void loop() {
if (keyboard.availablerel()) {
// read the next key
bool iskeyrelease = false;
char c = keyboard.readrel(iskeyrelease);
KeyboardHandler(c,iskeyrelease);
#define _SYNTHPRESS_STATUSCODE 0x90
#define _SYNTHRELEASE_STATUSCODE 0x80
void KeyboardHandler(char key,bool iskeyrelease)
  static bool c_pressed = false;
  byte synthstatuscode;
 byte volumecode;
 synthstatuscode = iskeyrelease ? _SYNTHRELEASE_STATUSCODE : _SYNTHPRESS_STATUSCODE;
 volumecode = iskeyrelease ? 0x00 : leadvolume;
   if(key=='c')
       if(!c_pressed || iskeyrelease)
        midiwrite(synthstatuscode, 40, volumecode);
      c_pressed = !iskeyrelease;
      return;
