Foam body design
A project log for Coilgun
This is an older project that i built for a physics contest.
e-c-c-0[ E C C 0 ] 04/26/2017 at 17:390 Comments
Initially, the body was made from insulation foam, just because it was easy to work with and it was what i had on hand.
However, this design proved weak in the middle. Also, i learned that the barrel needs to stay above the trigger, otherwise the gun is awkward to hold.
