Why not Raspberry Pi?
A project log for PewPew FeatherWing
A shield for Adafruit Feather boards with buttons and a LED matrix display, for simple games.
dehipudeʃhipu 08/06/2017 at 17:433 Comments
It seems that I have been blogged at https://hackaday.com/2017/08/06/hackaday-prize-best-product-finalist-pewpew/ and there are some questions as to whether it makes sense to do what I do when there is already a Raspberry Pi and all its retro-console builds.
Well, this is a little bit different. Sure, lots of game consoles using a Raspberry Pi out there. In fact, I have build one myself recently with #Ye Olde Nowt and I have to say that it is great fun. But it's not very good for teaching for the following reasons (in no particular order):
  1. You have to start by teaching Linux. That's a challenge already.
  2. Long booting time.
  3. Short battery time.
  4. SD cards get damaged when you power it off without proper shutdown, and then random things start to happen.
  5. Setting up the screen and inputs is a complex and somewhat hacky process. Not something you want to teach to a group of 14 year olds.
  6. Lots of existing emulators and ready games for this system. That discourages from making your own.
  7. No really good and simple game programming library for Python, although PyGame Zero helps here.
  8. Relatively high-resolution color graphics forces you to find game art somewhere and distracts from making the actual game.
  9. Raspberry Pi is not that cheap, if you consider the cost of the SD card, the screen, the power source, all the cables and adapters, etc.
On the other hand, I'm aiming at something that will be:
  1. Working out of the box, without special configuration. Connect to your computer, copy two files on it, and you are ready to play. Edit the files in place, and make your own game.
  2. Easy to fix. In the worst case just erase the memory, and you have your working device back.
  3. Simple. The library for it only has four functions (and one of them is for setting the brightness, so you don't even need to learn that one), and a single object with three methods. You can fit the documentation for that on a single page of paper.
  4. Portable. It's the size of an AA battery and runs on a single battery charge for hours.
  5. Powerful enough to be fun and engaging.
Of course, at some point you will want to switch to a real computer, pick up something like PyGame and continue from where you left, making more complex games. But I think this will be a really good stepping stone for starting.
Bartosz wrote 08/07/2017 at 17:17 point
the software is everytjing
deʃhipu wrote 08/07/2017 at 17:23 point
Only if you are "fixing it in software". If you design your hardware right, to be easy to use and simple, you don't need nearly as much software.
Orlando Hoilett wrote 08/06/2017 at 18:05 point
Makes sense. I like the simplicity of the Arduino and the LED matrix vs. the RPi and TFT so I can see where you're going with that.
