Microcontroller comparison
A project log for CEMN - Community Engagement Mesh Network
Under served communities can benefit from the exchange of information through local mesh networks to exchange critical notifications
miladMilad 06/12/2017 at 05:580 Comments
In this post update, We will compare different micro-controller candidates based on multiple criteria and examine each candidate as a possible processor option of each micro node.
The main two criteria of selecting the node micro-controller are the cost and availability of the micro-controller in the third world countries. Other criteria are power consumption, processing power, buffer depth for the Bluetooth and Wi-Fi links, memory speed and memory cost.
Small Memory size can be an issue if each node stores and forwards multiple message which can lead to a high message traffic even if only short text messages are sent. The micro-controller should be selected carefully to make sure each message is delivered. The node system can be slow as SMS without guarantee of timely delivery of messages but the system should not lose messages due to limitation of network data throughput.
Here are microcontroller candidates:
Raspberry Pi Zero W
Raspberry Pi 3 B
Raspberry Pi 2 B
Arduino Yún
https://store.arduino.cc/usa/arduino-yun
Arduino MKR1000
https://store.arduino.cc/usa/arduino-mkr1000
Particle Photon
https://www.particle.io/products/hardware/photon-wifi-dev-kit
Adafruit Feather nRF52 Bluefruit LE
https://www.adafruit.com/product/3406
Adafruit Feather HUZZAH with ESP8266 WiFi
https://www.adafruit.com/product/2821
Omega2
https://onion.io/omega2/
ODROID-C0
http://www.hardkernel.com/main/products/prdt_info.php?g_code=G145326484280
WiPy 2.0
https://www.seeedstudio.com/WiPy-2.0-p-2786.html
Intel Edison
https://software.intel.com/en-us/iot/hardware/edison
Summary
After comparing all the candidates,it can be concluded that raspberry pi zero W offers all the necessary features mentioned list of criteria. raspberry pi zero W has an affordable cost for third world countries and offers both Bluetooth and Wi-Fi Chip-set.The flash Memory can be extended by switching the micro SD card and external USB Antenna can be added as well.Omega2 offers smaller Memory size and requires external Bluetooth Chip-set which adds to the cost.WiPy 2.0 offers smaller Memory size comparing to raspberry pi zero W but it offers on board long range ( 1 KM ) on-board 802.11b/g/n Wi-Fi chip-set and on-board Bluetooth LE chip-set. WiPy 2.0 offers the option to add external antenna the extend Wi-Fi.
We will go over external antenna options in future posts/updates.
