Printing the pulley
A project log for Rotat-O-Mat
A Turntable for Time Lapse Videos
treibairtreibair 06/07/2017 at 09:360 Comments
As the build surface of my i3 is not big enough to comfortably fit the roughly 26 cm Diameter of the pulley, I segmented it into four pieces which came out of the printer this morning and will be glued and installed tonight. The motor is in place as well thanks to a 30 mm forstner bit and a file.
