Long overdue update
A project log for MIDI Stomp Box
An easy to build, simple to use stomp box for musicians using computerized effects for their electric/electronic instruments.
thenetimptheNetImp 03/12/2015 at 18:100 Comments
Well it's been a while since I've done any real work on this project. One of the things I am wanting to do is create a dedicated board for this that can be produced. What I am failing at doing is getting a circuit built that will take the Hiduino code. I had started with Atmega32u4 chip because I could get that locally in Akihabara. The hex file from Hiduino is targeted for the 16u2, so I bought a few of those from Digikey and tried to get that to work. That did not work. I have tried the circuits on the datasheet, I have tried a segment of the circuit from the arduino uno rev3 schematic. I am beginning to think it is the chip holder I got on ebay. I am going to search Akihabara for a board that I can solder this too and then give that a try. Probably late next week.
Until then I am going to start working on programming how I want it to work. I have a better idea of what I want 1.0 to be like. Currently it's working on an Uno, and I think I will keep the Uno for now. Going to integrate 5 pots for tweaking whatever anyone wants to tweak.
