Module improvements
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 08/10/2019 at 15:040 Comments
Changed the scanner and ported all designs to FreeCad. The scanner can be calibrated via set screws.
The scan head passes all tests; laser can be turned on, polygon rotates and the photo diode can be read out via the circuit.
