Video of new laser module
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 09/10/2021 at 16:292 Comments
I made a video of the new laser module!
Gravis wrote 09/10/2021 at 17:23 point
Wonderful!  Which motor board are you using now?  It seems like you are at the point where you could integrate everything into a single board which would significantly reduce production costs and make the modules much smaller.  This of course means finding out how to source a motor.
Hexastorm wrote 09/11/2021 at 10:26 point
I know use this module https://wiki.das-labor.org/w/Laserprojector_en#Horizontal_mirror (AN44000A).
Issues with the motor; non-linear scaling ergo twice pulse frequency gives total different speed.
Motor can lock into different modes with same signal applied.
Before I used NBC3111 which has linear scaling and lock in same mode.
It seems to be older and can only go up to 21000 RPM.
