PCBs..
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 12/17/2021 at 17:170 Comments
I succeeded in making some PCbs using laser direct imaging and prisms.
Track width of board below is 250 microns... the bronze colour is copper
In the following picture, you see a close up of a Bugeja coil, spacing between tracks is 150 microns.
There is a mismapping of 0.16 mm between reality and board (probably needs scaling factor) You can see this discrepancy back in the board.
