rod based 3d printing with laser prism scanner
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 05/04/2024 at 23:040 Comments
From fabbaloo, a new research paper proposes an unusual 3D printing process that uses a rod instead of a flat print plate.
It would make a lot of sense to remove the slit and the beamer. I would use  a laser prism scanner instead. The laser prism scanner can do 20k rpm x 8 lines. It would never need to stop..
I will get back to this
