Small Update [Pull-Back Mechanism]
A project log for Maker's Vise
The most general purpose hobby vise.
greg-stephensGreg Stephens 05/11/2017 at 23:200 Comments
As you can see, we upgraded the pull-back mechanism to a ball joint.
You may also have noticed the oil coating the through-bolt. Our next project will be to change out materials of the bolt feed-through, so that oil is no longer required.
