Checking the PMIC
A project log for Open SolarMote
A perpetually running wireless sensor mote.
dhqdhq 05/12/2017 at 00:410 Comments
Soldered the 2 first boards and took some measurements to verify the functionality of the PMIC chipset. The output resistor divider of the buck-boost circuit is programmed to output a 3V voltage. I hooked up a small LIPO battery and checked the power rails.
It works! Next step is to verify the energy harvesting capability
