Only a moment for a quick update, but things have been progressing nicely - the Quamera is going out in public on August 26th at the Dover Mini Maker Faire - if you've the interest and are in range of the NH seacoast, I would enjoy meeting you.
OK, the robot mast is done and operational - you can see it on the right side of this picture, the tall metal stick
Here's the control panel for the mast and power distribution close up - can't be taking bare wires out in public :-)
And this sad stack is the three camera rings - I've just perched them on top of each other, first time I've had the physical sense of their volume - when I started I thought the prototype would be the biggest version of the camera, now with the next one clocking in at 36 CPUs, I'm realizing it's the smallest by far . You can also see part of the mast at the right with the camera armature at the bottom (thats the part that goes up and down, the whole mast rotates)
I must admit, when I took this picture, I immediately thought of this.....
And if you want to see a pictorial history of this entire mad project, go here - https://goo.gl/photos/1ntMoSCMiD9ZYjqX8
