Design Improvements
A project log for Perf++ shields
We are experimenting with making Perf+ 2 like perf shields
chris-hamiltonChris Hamilton 05/22/2017 at 05:570 Comments
The initial run seems OK, though I think the through-hole could shrink and still be compatible with many components. I'll be shifting it around for Rev B, but the initial boards work OK. The silkscreen is off on some of the boards, but most seem to be aligned and legible. I'll remove the perf holes next to the connectors to provide more soldering space for riser connectors.
