Panels are in!
A project log for Stockie - item centric shopping list
What if every time you run out of a product, the smart tag on it would instantly add it to your shopping list, at the touch of a button?
electrobobelectrobob 08/18/2014 at 23:050 Comments
First panels are completed and can go online. Here are the first two assembled PCBs, one for development and one for actual usage in the kitchen.
DSC_2818DSC_2823
As you can see, there is a lot of empty space in the box, but I will design the whole thing again for the next version, the panel should not be much thicker than a battery and PCB. DSC_2828
The buttons are designed to come out of the box surface just enough so that they can be pressed through the front plastic panel that comes over them.
DSC_2830
And the first completed panel from the front which will take place in one of my cabinets in the kitchen. I have chosen the labels quite randomly, I almost never need flour, since I don’t cook. DSC_2832
