Vacuum sense
A project log for brdMaker
Advanced Pick and Place machine
mika-heikkinenMika Heikkinen 06/14/2017 at 16:001 Comment
There is very good support for vacuum sensing in OpenPnp. I finally managed to draw board for the sensor. Sensor(MPS20N0040D-D) sticks directly into vacuum channel. There is op-amp on board as well as 2 HALS for Z height sensing. Going to use SmoothieBoard temperature inputs for the vacuum sensor input.
MikeM wrote 08/23/2018 at 20:12 point
Mika - see here - for info; https://www.youtube.com/watch?v=DO8lbh_2isU
Mike
