Does it make sense to localize BASIC keywords?
A project log for Terminal-BASIC
Language interpreter for uC-based systems
Andrey SkvortsovAndrey Skvortsov 04/10/2019 at 22:030 Comments
As I wrote earlier, TB 2.0 (rc1 for now) has the ability to use different keyword sets in any single-byte encoding. If you are a TB user and if you consider useful some alternative keyword set in your native language, it can be included in future release of Terminal-BASIC. Now there was created a Russian keyword set, based on such, used in BASIC-6 system for БЭСМ-6 mainframe.
English
Русский
AND
И
DATA
ДАННЫЕ
DEF
ОПР
DIM
РАЗМЕР
END
КОНЕЦ
FN
ФУНК
FOR
ДЛЯ
GOSUB
ВХОД
GOTO
НА
IF
ЕСЛИ
INPUT
ВВОД
LET
ПУСТЬ
LIST
ЛИСТАТЬ
MAT
МАТ
NEXT
ЦИКЛ
NOT
НЕ
ON
ПРИ
OR
ИЛИ
PRINT
ВЫВОД
READ
ВЗЯТЬ
REM
КОМ
RESTORE
СНОВА
RETURN
ВОЗВРАТ
RUN
ПУСК
STEP
ШАГ
STOP
СТОП
THEN
ТО
TO
ДО
