Case design
A project log for UmbrellaMod
The last time you forgot to take or misplaced your Umbrella
sotirios-vrachasSotirios Vrachas 06/12/2017 at 14:000 Comments
I want to replace the stock handle of umbrellas with my handles that included the magic.
Experimented with clear nylon and clear petg 3d printing filaments.
After testing both the petg was a lot more clear, transparent, and was snappable making prototyping a lot easier.
I designed a concept case to test the lights and the defusion of tha petg. i sanded the case and then applied clear varnish. made a coin cell + led and enclosed it in the case to see how the lighting will work under different condition.
Dew to space constrains and the fact that one led dose not seep to be enough, concluded that smd leds will have to be used.
Took the dimensions of the original hanle and experimented with making a base for the common M14 screw umbrella's have for the handle mound
