Eye diagram measurements
A project log for Debug Board Isolator
Simple, tiny USB to UART converter, also with a galvanic isolation
SaimonSaimon 12/15/2017 at 16:320 Comments
Today at work, i got a chance to use some nice instruments at the labratory where i work. I did some measurements on the #DebugBoard Isolator and Voltage Translator TX signals.
I used the Keysight oscilloscope DSA91304A (13Ghz a40GSa/s) and the power supply Keysight N6705.
Yeah, those instruments are too much for this type of measurement, but they are the only ones that are available for me :D
I did the eye diagram at 3 Mbaud and at the minimum and maximum voltage level, here are the results:
Debug Board Isolator at 1,8V:
Debug Board Isolator at 5V:
Debug Board Voltage Translator at 1,2V:
Debug Board Translator at 5V:
The result seems pretty good!
