things are stacking up in a good way
A project log for Getting Nibbles to run on a Tandy 1000A
Getting Qbasic Nibbles to run on an IBM Compatible PC, easy rite? Not when the computer is a Tandy 1000A with 128KiB of RAM!
eric-wrightEric Wright 08/02/2014 at 08:400 Comments
I started working on the prototype tonight, armed with a general idea of what I wanted (and that included not wanting to do 24 connections on 16 different chips), I started tacking two sets of 8 SRAM ICs together. once both sets were all tacked together, I went thru and soldered the other common pins together. After getting the two sets of SRAM together, I decided that I should hammed out the memory decoder/demux so I hammered out a quick schematic based on the memory map I had created earlier
tomorrow at some point, I will scavenge around to locate the 4 7400 series ICs that I need and start to assemble the board.
