Switching Op Amps
A project log for ECG ADC Buffer Flex Module
ECG Sensor summing amplifier and RC filter for feeding Plessey biosensors to an ADC. For sale on Tindie.
chris-hamiltonChris Hamilton 06/24/2015 at 21:540 Comments
After a seminar by ST, I will be reworking the opamp to be a TSZ124. Also, Plessey recommends the low pass roll off be around 200Hz and that I use the 10x gain not the 50x gain sensors. So not the PS25251, but the PS25253 nor the PS25451, but the PS25454. The advanced Notch filter design works great, so I'll be releasing an updated version of it and this board (which is good for differential ADC) with a new low pass filter. I'll be working on a 2 channel design that utilizes the TSZ124 in both a filter and gain configuration soon.
