Wireless transceiver choices
A project log for Aurai - retrofit dumb air conditioners
Helping traditional air conditioners join the Internet of Things.
thomas-rThomas R 08/06/2014 at 00:400 Comments
The two components communicate wirelessly. There were several options I considered for this link.
# Ethernet on the controller, wifi on the receiver
* Pros: good library code available, entire stack on the chip, high level protocol (http?)
* Cons: expensive, hard for the end user to set up
# XBees
* Pros: reliable, lots of library code, stack
* Cons: moderately expensive, no hardware UART on the ATTiny85
# Nordic Semi NRF24L01
* Pros: inexpensive ($3/pair), compact, respectable range - even indoors
* Cons: not a lot of library code out there, lower level protocol.
In the end, I decided to go for the NRF24L01 and purchased some sample units to use in this process.
