Test Setup
A project log for Contactless Loop Controller
Box to control the loop for metal stamping process.
jlbrian7jlbrian7 02/05/2016 at 13:010 Comments
This is the test setup:
I believe that some of the reason for the variation in the data, other than the outliers, is from the book not being parallel to the sensor, or my wobbling it back and forth, but none the less it worked well enough.
250 samples were taken at each inch.
