Proof of concepts part 2 delayed
A project log for Nintendo Controller Noise Maker
AVR inside a Nintendo controller that makes sounds when the buttons are pressed.
benBen 08/13/2014 at 05:260 Comments
First off, the knockoff controller was a bit disappointing.  The PCB uses a chip-on-board shift register and is very small leaving plenty of room for extra components, but it just doesn't have the original controller feel.  Luckily, I have a local shop that I was able to procure an original controller from.  I've done some measuring and I think I can cram all of the components into this space after cutting out the columns (see red box in image).  I'll need to use a different speaker though; I'm currently testing sound quality on a few speaks that I have laying around and will post which one I choose.  I've also decided that since I won't have a good time to work on this unit this weekend anyways that I'll wait and pick up some dead NES components from my local shop and use them to make a controller breakout board.  This is largely due to the connectivity issues I had while testing the knockoff board as the connector sockets are too large to support my male-to-male perf-board wires.  The wire size issues caused my initial test to get a lot of false positive button presses during my tests and I think it would be useful to solve this before choosing beyond a doubt which controller I should move forward with.
