Power testing: TPS61220
A project log for BlueBasic: BASIC for Bluetooth
Embedded BASIC interpreter for CC2540 and CC2541 Bluetooth LE modules
tim-wilkinsonTim Wilkinson 09/12/2014 at 01:091 Comment
The second power testing board turned up today, the TPS61220. Running this board with the CR2032 battery in the same configuration as the previous test, the board consumed 49uA. This is a little better than the LTC3525. This board also has an easy enable/disable switch. With the module disabled, the power consumption is 34uA; 6uA more than bare configuration. So, given testing, I think I'll go with this module. It's also half the price which is an added bonus.
Tim Wilkinson wrote 09/12/2014 at 01:29 point
TPS61221 is the 3.3v fixed version.
