Instruction ST A, [addr] and research to 2nd gen CPU
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 05/25/2017 at 19:410 Comments
Still lacks the ST A, [addr] instruction, to save the contents of tha A register to the RAM (actually, the register has only 4 bits and each RAM cell is 8-bit, so it uses just the 4 less significant bits, and the other bits are set to 0, kind of odd, I know, but it's just a proof of concept).
I'm procrastinating a lot this last instruction, because I'm deeply buried in TTL research to the 2nd generation CPU, JACA-2...
Let's see what I chose so far:
-2x 74181 for ALU
-for registers: 74HC574
-for RAM: CY62256
What do you think about these choices? Would you use others?
