9-5 Lunchbreak
A project log for Wi-Fi Controlled Open Scoreboard
A open design for a portable scoreboard that can be controlled over Wi-Fi, and integrated into event management software.
christopher-kratzChristopher Kratz 09/05/2014 at 17:530 Comments
Progress is slow. Currently decided to swith the driver design to use an optocoupler since I was going to use transistors to drive the FET gates anyways. Isolating the power from the logic probably isn't needed but couldn't hurt, and males the board more version's for other uses.
