Build log - take 2
A project log for PSU Burner
What does one do when designing a power supply? Well, build a power supply tester, of course.
electrobobelectrobob 05/23/2017 at 20:290 Comments
Build pictures
Transistors tanning. Notice how this heatsink has been through a lot…lots of holes.
First tests, including cooling:
Preparing to put things together:
First test. The front panel is 3D printed. Also the knob, I did not have one for perfectly cylindrical shaft multi-turn potentiometer.
Testing the power brick guilty of burning the previous transistors. After a long time, the heatsink reached about 45°C in the middle at the well cooled area and 53°C at the edge fins where there is not much air flow.
And finally testing the speed using a 7805 regulator and short output wires using a 10kHz, 1A load. The rise and fall time are about 2.1µs.
