Back to this Project
A project log for WIFI Interface Board
This board allows experimenting with a WIFI link on a general purpose MCU.
bharbourBharbour 09/03/2017 at 22:001 Comment
I just finished up a contract gig, so I will be back working on this for a while.
I wrote and did some testing on a real user interface for the system. It is a text based parser. The user interface will be used rarely once the system is deployed, it is for configuration and debugging. More thorough testing on the user interface is in order before calling it done.
There is still some cleanup work to do on the Radio Manager code and the SMTP code, but that should be fairly quick. Then is is time to start working on the sensor code that will trigger the operations.
yanisbb1 wrote 08/11/2019 at 20:36 point
hello can we talk this is my email adam40sp@gmail.com
