Where are the Starlings ?
A project log for Wild Eye
To capture the image and breed of the animal using OpenCV and Node-RED Watson Visual Recognition
brenda-armourBrenda Armour 06/05/2017 at 19:560 Comments
I only had short periods of time to get the camera outside over the weekend. This was mainly due to rain. The Starlings were in the field but when I left some bird feed only the crows came. So I decided to start setting up the Intel Joule. The power supply arrived but the RealSense camera will not arrive until June 14th.
I had added my own USB B cable and decided to use Putty as the console. The first step was to connect the Intel Joule to my laptop and make note of the COM port. I already had the FTDI drivers and Putty installed from a different project.
This step came from the guide . The link is here.
Once Putty is running a command line I connected to our WiFi.
