ZCD
A project log for 8ch dimmer
8 channel classic dimmer in a DIN box
crazychipCrazyChip 08/20/2014 at 12:040 Comments
The original Zero Crossing Detector developed:
https://cdn.hackaday.io/images/5109501408535937213.jpg
The resistors limit a current and the diodes limit a voltage from the bridge. RC output filter reduces the noise from mains. Both outputs from RC filters must be connected to Atmega's comparator. Such schematic uses two pins of Atmega.
