Optical assembly printed!
A project log for MakerFoundry
DIY Semiconductor fabrication using maskless lithography
polyfractalpolyfractal 06/30/2017 at 21:154 Comments
Four revisions later (fiddling with printing tolerances, and poorly measured components), I have a complete optical assembly with the laser, objective and LCoS system.
Next step is to print the top half and run some tests to see if it works!
Gravis wrote 07/01/2017 at 10:13 point
I'm excited to see if it works as intended. :)
polyfractal wrote 07/01/2017 at 11:00 point
Me too!  I'm really hoping I got everything aligned, and all the respective pieces were put back into their correct location.  Otherwise troubleshooting is going to be... fun :)
Testing it this weekend, stay tuned!
RoGeorge wrote 07/01/2017 at 08:30 point
What software did you use to make the arrow type annotations, please?
polyfractal wrote 07/01/2017 at 11:01 point
The program is called Skitch (I'm on a mac, not sure if it's available on windows/linux): https://evernote.com/products/skitch
There is a trial version that is free.  You can't save, but you can take screenshots of what you've created which is what I'm doing :)
