prototype 1
A project log for TORLO
a 3d printed electromechanical clock
ekaggrat singh kalsiekaggrat singh kalsi 06/07/2017 at 02:570 Comments
The first prototype used the final motor and a attiny2313 with a clobbered together pcb. The base is just supporting the clock on one side giving it a sense of floating mid air.
One snag i ran into was that the base was too light and the clock would topple. So i added 75x5 mm studs in the base to give it some mass
