Rover
An uncreatively-named autonomous robot project.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Rover will be a small autonomous ground vehicle capable of navigating to given waypoints while planning a route, avoiding obstacles, and mapping its environment as it goes. This robot could be used to take sensor measurements along a given route or to do tasks at certain locations - agricultural uses come to mind.
Rover's hardware is a prototype, and will likely be refined along the way. Software is loosely based on the Udacity/Georgia Tech OMS CS course "Artificial Intelligence for Robotics" from Sebastian Thrun. It turns out that doing this in the physical world is much more challenging than in the lab :)
