Blimp rev 3
A project log for Remote Control Mini Blimp!
Mini blimp flies through hoops! Features 3 DC motors/ propellers, battery charging, and wireless communication.
Sophi KravitzSophi Kravitz 04/05/2018 at 01:014 Comments
Putting this PCB together has been quite a journey.
While soldering QFNs I broke down and purchased a microscope and a hot air tool. The hot air tool was really cheap and is already loudly rattling after only a month in the shop.
I just received a board back from @oshpark that has some new accoutrements:
It is all working well and it is the correct weight.
Things to fix in next rev:
Ted Yapo wrote 04/05/2018 at 13:20 point
How much less does it weigh with the props turning? :-)
Sophi Kravitz wrote 04/05/2018 at 16:57 point
HAHAHA. I measured thrust at 4.7 grams. Uploading image now :)
oshpark wrote 04/05/2018 at 03:02 point
Very exciting to see your progress.  We love the board design.
zakqwy wrote 04/05/2018 at 02:32 point
tag connect! the only programming connection that _saves_ weight.
