Rev 2 (posting for @davedarko)
A project log for Remote Control Mini Blimp!
Mini blimp flies through hoops! Features 3 DC motors/ propellers, battery charging, and wireless communication.
sophi-kravitzSophi Kravitz 10/31/2017 at 03:224 Comments
Here's a rendering of the new design. Might lose some of the diagnostic LEDs before sending it out. (Yes, I lost 2 LEDs before sending it to @oshpark ).
Not really sure the best way to layout the ESP-12S...is the antenna in an OK place?
Paul Andrews wrote 11/01/2017 at 14:23 point
To save more weight, you could cut the PCB out from under the antenna, up to the edge of the PCB.
Sophi Kravitz wrote 12/04/2017 at 13:39 point
Done!
Jarrett wrote 10/31/2017 at 06:25 point
Antenna looks okay, just don't put a ground plane below it!
Actually, you could shave a lot of weight be not putting ground pours over most of the board
davedarko wrote 10/31/2017 at 06:14 point
yay :) you could always add leds to a board for testing and dont populate in production ;)
